Artikel-ID : 00273655 / Zuletzt geändert : 11/03/2025Drucken
Notice to owners of the Professional Disc PFD23AX
    Decmber 10, 2021
    Dear Valued Sony PFD Customers,
    Sony have discovered there were some minor issues (deformation) caused in the manufacturing process of single layer models of PFD23AX.  This issue means that the drive may unexpectedly stop while insert editing.
    Despite the issues while insert editing, we can confirm that the PFD23AX can be used without any problems with recording and playback.
    If you have purchased PFD23AX with the corresponding serial numbers and are experiencing difficulties with insert editing, we would like to offer a free exchange of the professional disc. The details around timing of replacement discs will be discussed on a case-by-case basis. The issue of a free replacement will be made on an ex-gratia basis without acceptance of any liability in respect of this issue.
    We sincerely apologies for any inconvenience this may cause.
    • Applicable model
      PFD23AX
    • Applicable LOT number
      Please check the lot number printed on the master carton, or sub carton, or cartridge disc. If the last 2 or 4-digit is match with below numbers, they’re applicable ones.
      *******6X, *******7X
      *****215X, *****308X, *****315X, *****408X, *****415X, *****425X, *****525X, *****625X, *****715X, *****725X
    • Location of the LOT number
      Master carton
      It is printed on the labelled sticker on the master carton. The LOT number is the 9-digit code under the barcode. All 10 sub cartons packed in the master carton have the same LOT number.
      Sub carton
      It is printed on the labelled sticker on the sub carton. The LOT number is the 9-digit code under the barcode. All 5 cartridges packed in the sub carton have the same LOT number.
      Cartridge disc
      It is printed under the barcode on the back of the cartridge disc. The initial 9-digit represents the LOT number and the latter 6-digit after the dash (- symbol) shows the serial number. Please check only the LOT number to check the cartridge is applicable.
    • Action
      Sony offers the product exchange free of charge. For further information, please contact our PrimeSupport helpdesk.
    CountryPhone*Emaillanguage
    Austria+43 (0) 1206092545primesupport@sony.comGerman
    Belgium+32 (0) 25855099primesupport@sony.comEnglish
    Belgium+32 (0) 25855100primesupport@sony.comFrench
    Bulgaria+359 (0) 8002100308primesupport@sony.comEnglish
    Czech Republic+42 (0) 239050085primesupport@sony.comEnglish
    Denmark+45 (0) 43310564primesupport@sony.comEnglish
    Finland+35 (0) 8972522246primesupport@sony.comEnglish
    France+33 (0) 186995593primesupport@sony.comFrench
    Germany+49 (0) 69945189344primesupport@sony.comGerman
    Greece+30 (0) 2103007328primesupport@sony.comEnglish
    Hungary+36 (0) 17799000primesupport@sony.comEnglish
    Ireland+35 (0) 317617264primesupport@sony.comEnglish
    Italy+39 (0) 689386345primesupport@sony.comItalian
    Luxembourg+35 (0) 23420808838primesupport@sony.comFrench
    Netherlands+31 (0) 207003700primesupport@sony.comEnglish
    Norway+47 (0) 24055243primesupport@sony.comEnglish
    Poland+48 (0) 223064185primesupport@sony.comEnglish
    Portugal+35 (0) 1707201648primesupport@sony.comEnglish
    Spain+34 (0) 918362963primesupport@sony.comSpanish
    Sweden+46 (0) 851989692primesupport@sony.comEnglish
    Switzerland+41 (0) 445246529primesupport@sony.comGerman
    Switzerland+41 (0) 445246530primesupport@sony.comFrench
    Switzerland+41 (0) 445246531primesupport@sony.comItalian
    United Kingdom+44 (0) 2039015558primesupport@sony.comEnglish
    (*) For countries not listed or for general PrimeSupport enquiries contact the UK helpdesk on +442039015558
    Opening hours: Monday-Friday 9:00 – 18:00, excluding Local National Holidays
