Betroffene Modelle
- MPC-3610 / VENICE
Sony is offering a system firmware update for Digital Motion Picture Camera VENICE “MPC-3610”.
[Note]
The latest Version has been released.
Click here for a list of software >
To upgrade from V3.00 or earlier, it is necessary to change the hardware in advance.In this case, please contact Sony sales representative or dealers for getting firmware. Customers in Europe can contact PrimeSupport via email or call using phone numbers on our contact page. Please remember to provide your serial number when contacting us.
[Applicable model]
[Applicable system software version]
The applicable products have system firmware version “Ver.4.00” or later.
After updating, the system firmware version will be “Ver.6.00”.
<Contents of update>
1. Imager mode FPS expansion (5.7K 16:9 72FPS, 4K 6:5 72FPS, 3.8K 16:9 110FPS)
2. ART file support added to look
3. User 3D LUT added to viewfinder output
4. Added selectable SDI 3G LevelA output function
5. Added support for two types of user frame lines
6. Added support aspect ratios for frame lines (1:1, 9:16)
7. Addition of flicker reduction function
8. Separate adjustments for REC beep and alert sounds
9. Improved display funcition (Genlock & timecode Lock condition, status disp on the web remote panel)
10. Improved metadata operation (Tint/Roll information, Zoom extended metadata)
11. Others
IMPORTANT: Installation of firmware is at owner’s risk. Please refer to our terms & conditions for details. Prior to installation always read installation instructions.
Note: UpdateManual and ReleaseNote are included in the zipped download file with main firmware module.
